Home Window
Main Window Image
The Home Window has 4 areas:
  1. Outline View
  2. Item List
  3. Item Detail
  4. Status Bar
Outline View
Outline View Controls Image
To create a new folder, select the main object type in the list then click the plus (+) button lower-left corner of the outline view. A new folder will appear and you can just start typing its new name.
  • Rename Folder... allows you to rename the folder.
Item List
Device Contextual Menu Image
This menu will:
  6. Copy a Python script string that will return an instance of the selected device. It will look like this: indigo.devices[91776575] # "Living Room Switch"
    address : 3B.04.7A
    batteryLevel : None
    blueLevel : None
    brightness : 0
    buttonConfiguredCount : 0
    buttonGroupCount : 1
    configured : True
    defaultBrightness : 100
    description : valve
    deviceTypeId :
    displayStateValRaw : 0
    displayStateValUi : 0
    enabled : True
    energyAccumBaseTime : None
    energyAccumTimeDelta : None
    energyAccumTotal : None
    energyCurLevel : None
    errorState :
    folderId : 810233868
              publish-device : true (bool)
              sub-type : Valve (string)
              voice-name : valve (string)
    greenLevel : None
    ledStates : []
    model : LampLinc (dual-band)
    onBrightensToLast : False
    onState : False
    pluginId :
    protocol : Insteon
    redLevel : None
    remoteDisplay : True
    states : States : (dict)
         brightnessLevel : 0 (integer)
    subModel : Plug-In
    subType : Plug-In
    supportsAllLightsOnOff : True
    supportsAllOff : True
    supportsColor : False
    supportsRGB : False
    supportsStatusRequest : True
    supportsWhite : False
    version : 67
    whiteLevel : None
    whiteLevel2 : None
    whiteTemperature : None
  1. Enable/disable the event.
  5. Copy a Python script string that will return an instance of the selected device. It will look something like this: indigo.triggers[565290390] # "Motion Sensor Dawn Triggered"
  4. Copy a Python script string that will return an instance of the selected device. It will look something like this: indigo.actionGroups[1703232002] # "Toggle Variable"
  4. Copy a Python script string that will return an instance of the selected device. It will look something like this: indigo.controlPages[249813574] # "iPad Landscape"
Item Detail
Device Details Tile Image
Custom States Tile Image
Device State Context Menu Image
Lights/Appliances
On Off Dimmer Tile Image
Color Controls Tile Image
Sensor Controls Tile Image
Speed Controls
Speed Controls Image
Speed control devices are devices that can control the speed of some kind of motor. For instance, the Insteon FanLinc. And, in fact, the controls are currently tailored to the FanLinc's High, Medium, Low, and Off settings. When we run across more of these types of devices we'll customize the controls appropriately.
Sprinklers
Sprinkler Controls Image
Thermostats
Thermostat Controls Image
Generic Output Devices
I/O Controls Image
Triggers and Schedules
Action Group Controls Image
Control Pages
Status Bar
The next four sets are pretty self-explanatory: the next sunrise time, the next sunset time, the current time (for the Indigo Server, so it may be different than the client time if you're running the client on a different machine), and the next time a schedule is going to execute.
