PowerLinc 2413S
In this guide
Setup instructions for users running the PowerLinc 2413S serial Insteon interface via a USB-to-serial adapter. Includes a factory reset procedure for units previously used with another home controller (ISY, etc.) and driver installation notes.
Although Indigo officially supports the USB PowerLinc 2413U interface, users have reported success using the serial version (2413S) along with USB-to-serial adapters. Note that if the 2413S was previously used with another home controller (ISY, etc.), then you should first factory reset it:
  2. Unplug the PowerLinc 2413S from the wall outlet.
  3. Hold down the SET button on the device for 20 seconds.
  4. While still holding the SET button, plug it back into the wall and keep holding the SET button for 20 additional seconds, then release.
  5. Install the USB-to-serial adapter driver, plug the adapter into the 2413S and your Mac, then select the correct Serial Port in the interface settings for the device.
