Accessing Indigo Remotely
Remote Indigo Access
The following steps explain how to access the Indigo Server from within the local area network (LAN) of your house. Configuring your network to allow Indigo Server access from outside your home (on the other side of your router/cable modem) is more complex and will depend on your network topology, router type, and ISP features (static versus dynamic IP addresses). For this reason, we are only providing instructions on how to get local (in-house) remote access to Indigo Server.
Alternatively, you can configure your network by consulting your router user manual and, if your ISP does not provide a static IP address, using a dynamic DNS mapping service like DynDNS.com. Because of the potential complexity involved in manually configuring networks and routers for this type of access, Perceptive Automation cannot provide direct support answers about router port forwarding or IP discovery issues. Users having difficulty configuring their networking hardware should post on the online support forum. Be sure to include details about the type of hardware you have and what steps you have tried.
Modifying Firewall Settings
Firewall Prompt Image
IPH Firewall Prompt Image
The Indigo Web Server advertises itself via Bonjour, so Indigo Touch and Safari (by clicking on the bookmarks icon, then selecting Bonjour) will automatically find any local servers. In addition to that, when connecting to a local server for the first time, Indigo Touch will also automatically fetch Reflector settings for that connection so that you'll be able to connect outside your LAN via LTE/4G/3G/EDGE.
Network WiFi Image
and a wired Ethernet connection might look something like this:
Network Wired Image
  1. If you haven't already installed the client on the remote Mac, run the Indigo Installer on the remote Mac and on the Installation Type step click the Customize button. Deselect everything except the Indigo Client line and click Install.
  2. Double-click the Indigo 2026.1 application (inside /Applications/Indigo 2026.1.app) on the remote Mac.
  4. If you want to connect to a different Indigo Server, then select the Indigo 2026.1->Connect to Remote Server... menu item.
  7. Press the Connect button.
Client Connect Dialog Image
Indigo Mac Client and the Indigo Reflector
The Indigo Mac Client doesn't use the Indigo Reflector service. Connecting an Indigo Mac Client to a server over the Internet is a complex topic that is well beyond this document — we suggest you search our online forums for others that have configured this type of access.
At this point, Indigo Touch will also query the server to see if you have an Indigo Reflector set up for the server. This makes connecting to your home server via Indigo Touch completely seamless. If you have a reflector set up and running, then Indigo Touch will automatically attempt to connect no matter where you are or how you're connected. If you're local, it will use the local Wi-Fi network. If you're on a remote Wi-Fi network, it will attempt to use the reflector account. If you're iPhone is on LTE/4G/3G/EDGE, it will also attempt to connect via your reflector account. This makes Indigo Touch truly location agnostic!
You can, however, configure a connection manually. Simply tap Manually Add Server on the Settings screen in Indigo Touch and you can enter your host/IP address and port number.
http://192.168.1.23:8176/
See the using Control Pages section for information on how to create custom browser-accessible interface pages.
Once Indigo automatically detects your reflector address, it will seamlessly change between using the local Bonjour-detected address and the remote reflector address. Just launch Indigo Touch and it works, no matter where you are!
  1. Shut down the Indigo Server (select Indigo 2026.1->Stop Server) but don't quit the Indigo Client
You should now see an Activate Reflector button toward the bottom of the dialog. Click that, log in to your reflector account, and select the appropriate reflector. If the reflector you want to use doesn't show in the list of inactive reflectors, contact us with the name of the reflector you're trying to activate and what steps you've performed.
Manual Reset
  3. Go to the reflector list in your Indigo Account (you'll need to log back in) and click the Reset link beside your reflector's status (it should say Activated before you press Reset). If the reflector has already been deactivated that is fine — just skip this step.
  4. In the Finder, select Go->Go to Folder…
  5. In the resulting dialog, copy and paste the following: /Library/Application Support/Perceptive Automation/Indigo 2026.1/Preferences/
