Control Pages
Control Page Editor
Control Page Editor Image
The editor window has 4 areas - the first is the global control area. In this area you'll find buttons to create new page elements (labels, controls, etc), duplicate existing elements, delete elements, and turn on/off some features of the editor. Select Snap to grid to have page elements snap to a grid that overlays the design area (see the next item). Select Show grid to show the aforementioned grid. Select Edit z-order to show you the order of the page elements and allow you to change them. Higher numbered elements are drawn last, so if you have overlapping controls the one with the highest order will be drawn last.
Page Element Examples Image
If you have a page element that's showing a textual description, then you'll notice a little resize icon at the lower left corner of the text - this control will allow you to adjust the width of the text field so that it can accommodate longer text. Text can only be a single line at the moment but you can make it as wide as the entire page.
If you aren't using a background image, your background image is smaller than the total size of the page, or if your background image has transparency identified, you can specify the color of the rest of the background by clicking on the Background color: color well. Finally, you can have the page size constrained to the size of the background image or you can specify your own page size. Here are a few design tips for designing pages for Indigo Touch on various devices:
  • iPhone/iPod touch
  • iPad
If you look closely at the numbers, you'll see that on the iPad, the Indigo Touch header that's displayed above the control page is 64px regardless of screen orientation. However, it appears that the header is decreased to 52px when in landscape mode on the iPhone/iPod touch. This is verified in both iOS 3.x and 4.x.
Other Editor Features
Page Element Details
As we stated above, each page element represents some kind of object - also called controls. Specifically, there are 6 different types of controls.
Device State
The next row of options allows you to have the control represented by an image or in text. Images may be used to represent the state of most common devices - we provide quite a few different images. If you'd like to use custom images, check out the section below on creating and using custom images.
The next two options, Client action: and Server action: allow you to specify what happens when the control is interacted with (via click or tap) and are described in separate sections below.
Variable Value
Static Image/Caption
Refreshing Image URL
You can include markup that will do variable (%%v:VARIDHERE%%) and device state (%%d:DEVIDHERE:STATEIDHERE%%) substitutions as a part of a refreshing image URL. Note: file paths that contain spaces will need to have the spaces escaped with a backslash - /some\ path/that\ has/escaped\ spaces/. When you use substitutions in refreshing image URLs, you will receive a warning in the event log (when you edit the control page -- not each time the control page is displayed):
Server Status Text
Server Status Icon
Client Actions
For every page element, you can have one of six client actions performed whenever the page element is clicked/touched:
  2. Advance to Control Page - this will cause the client to display the selected control page. This version will leave breadcrumbs so you can come back to the current page using the back button (a new browser window if the Opens new window checkbox is checked).
Server Actions
Show in Browser
Custom Images on Control Pages
There are several subfolders to add custom images to control pages inside:
/Library/Application Support/Perceptive Automation/Indigo YYYY.R/Web Assets/images/
Note: Indigo 7 and earlier store the images inside:
/Library/Application Support/Perceptive Automation/Indigo X.Y/IndigoWebServer/images/
And also note that's the Library folder at the top level of your hard drive, not the one in your user directory. You'll find a couple of directories under there:
  • backgrounds - put images here that you want to use for control page backgrounds
  • controls - in this directory, there are 3 more:
    • devices - in this directory, put in images to represent devices. In Indigo 4.1 and higher, we've added some heuristics that will allow you to add many more images. See Image Selection Heuristics below for details.
    • static - in this directory, you can just put static images that are shown when you select Static Image / Caption from the Display: popup in the control page editor.
    • variable - in this directory, you can put images that represent variables. In Indigo 4.1 and higher, we've added some heuristics that will allow you to add many more images. See Image Selection Heuristics below for details.
So, adding images is as simple as inserting them into the correct directory above based on what you want to use them for and restarting the Indigo Server. Images should be in the PNG format. When upgrading Indigo, v7 and above should automatically move over any custom images, but you may need to move them over manually if upgrading from an older version. Also, if you edit an existing custom image, you may need to restart the client (or clear the cache in Indigo Touch from the settings dialog) in order to see the changes.
Before v4.1, we had a simple mechanism for selecting images based on values: for devices, you could have a file named MyDeviceImage.png, which would be shown if the device was OFF, and MyDeviceImage+on.png, which would be shown if the device was ON. Likewise, for variables, you could create an image called MyVariableImage.png, which would show when false, and MyVariableImage+true.png which would show when the variable value was true.
We've expanded the image selection criteria so that it can find much more interesting images based on values. To signify that an image should use these more complex image heuristics (described below), end the base file name with a "+": ImageName+.png. The "+" at the end is a hint to the Indigo Web Server and Indigo Touch that it may need to contact the server for the right image. The heuristic works like this now:
  1. Search for an image of the form ImageName+VALUE.png, where VALUE is the current value. For ON/OFF type devices it will be on and off, just like before. For devices that have numerical state values (brightness, temperature, etc.) it will be the numerical value for that state. For variables, it's a bit different: it will be an exact match of the current value of the variable. So if your current variable value is "summer", then we'll look for an image named ImageName+summer.png. Spaces should work correctly as well, but other special characters may cause problems, so be careful as you plan specific values. If the variable value is empty then the base image ImageName+.png will be used.
  2. If a match isn't found above, then Indigo attempts to find a numeric match in the following way: search for an image with a name that is the closest increment counting by 5. So, for instance, if the value of the device or variable is 13 (and there was no exact match to ImageName+13.png), we'll look for an image named ImageName+15.png. If that isn't matched, we'll look for the next closest increment counting by ten (in this example, ImageName+10.png since 13 is closer to 10 than to 20). Next, we'll look for the next increment counting by 20 (ImageName+20.png). Finally, if that isn't matched, we'll look for the next increment counting by 25 (ImageName+25.png). This will work for variables that are valid integers (whole numbers) as well.
  3. If neither #1 nor #2 match, then the intention was to have the base image ImageName+.png displayed. (A bug in image selection in Indigo 5 and fixed in later versions however will result in no image. A workaround is to add an image named ImageName+true.png which will be used in this case.)
Note that the dimensions of all the images with the same base image name must be the same. If they are not, the layout of some of the images will be incorrect.
We think this will give you much more flexibility in displaying images that match your needs. This works for all control pages regardless of whether they're viewed in a web browser or in Indigo Touch.
