Text Field
A text field is used to collect text input from the user. The following table describes the attributes that are available for text fields.
Attributes
enabledBindingNegate No 1.9 Set this to "true" to negate the binding. So if the target binding field's value is true then the binding will be false.
    <Label>Text Field:</Label>
</Field>
Back to Configuration Dialogs
