Devices.xml
Device Types
Name Type Required Notes
ConfigUI Element No This is the custom UI for configuring the device. It’s optional, but in reality we can’t envision a device that needs no configuration. If the optional <ConfigUi> element is not used, the "Edit Device Settings…" button will be displayed, but disabled. You'll also need to manually set dev.configured = True and then dev.replaceOnServer() for the change to take effect.
<?xml version="1.0"?>
        <ConfigUI>
            </Field>
        </ConfigUI>
            <State id="temperature">
    </Device>
Device Subtypes
Note
There are no device subtypes for other built-in devices at this time.
In Devices.xml
<Device type="sensor" subType="kSensorDeviceSubType.Temperature, ui=Outdoor Temperature" id="my_temp_sensor">
Device Subtype Example Image
In Python:
newdev.name = u"Device 1"
When the allowUserCreation attribute is present and set to false, Indigo will not display the device model type when the user elects to create a new device (the "Model" dropdown will not contain the device type). This is especially useful for complex devices that have multiple subtypes that are set programmatically (but not created using the Device Factory approach). Your plugin may not support individual subtypes as stand-alone devices and, therefore, you wouldn't want users to be able to create them. The allowUserCreation attribute was introduced with Indigo version 2022.1.2 and API 3.1.
Important
Plugin developers should account for each devices' callbacks when implementing built-in device types -- even if you don't use all the callbacks within your plugin. For example, if your plugin implements the Speed Control device type, your plugin should include handlers for all the Speed Control callbacks -- such as turnOn, turnOff, or toggle. This is very important because these callbacks will still be exposed in the Indigo Client UI for things like Actions and Triggers. It's best to give users an indication that the callback won't do anything in your plugin by writing a warning to the Event log. Consult the SDK for more information on each device types' callbacks and examples of how to handle them.
Custom Device Type
        <ValueType>Number</ValueType>
    <State id="heatSetPoint">
    <State id="coolSetPoint">
    <State id="mode">
Each State listed in the States element will be available in various parts of the UI, including the "Device State Changed" Event dialog.
Attributes
Attribute Type Required Notes
readonly Attribute No If you want this state to be read only, set this attribute to "YES". For instance, as in this example, the temperature the thermostat is sensing isn’t user settable. (Currently unused but it may be used in the future)
ValueType Element Yes This is the type of the state, which must be one of the following: Boolean, Number, List (enumeration constructed just like the <List> element of a <Field> as described above), String, and Separator (used only to visually group your states in the various popups). The <ValueType> element may also have an optional attribute if the value is Boolean//: boolType can be: "TrueFalse" (default), "OnOff", "YesNo", and "OneZero". Example: <ValueType boolType="OnOff">Boolean</ValueType>//
TriggerLabel Element Yes When selecting "Device State Changed" type trigger events, you can select your device in the resulting list. A popup below the device will list all of your States using this text.
TriggerLabelPrefix Element No When defining an enumeration, trigger change label is usually going to need to be a bit different than just the trigger label ("Mode Changed to Heat" vs "Operation Mode Changed" - the former is to test a specific change, the latter will trigger on any change). To accomplish this, you can specify a prefix that’s prepended to the actual state value (with a space in between). See the example above.
ControlPageLabel Element Yes In the Control Page Editor, when selecting "Device State" as the display type, then select your device, the next popup will show all your states using this text.
ControlPageLabelPrefix Element No When defining an enumeration, the control page label is usually going to need to be a bit different ("Mode is Heat" vs "Current Mode" - the former will show whether a the state is true, the latter shows the state value). You can specify a prefix that’s prepended to the actual state value (with a space in between). See the example above.
The ValueType element is particularly important - it controls what types of controls are presented to the user in the UI: an integer tells it to show greater than, less than, equal to, not equal to, etc. and a way to enter a number (in the case of a trigger).
Device Factory
One way to create "multifunction" devices is to use Indigo's Device Factory method. Device Factory devices are defined by using a special <DeviceFactory> node in Devices.xml. A basic Device Factory device definition would look something like this:
<DeviceFactory>
    <ConfigUI>
        </Field>
            <Label>Name:</Label>
        </Field>
    </ConfigUI>
</DeviceFactory>
<DeviceFactory>
    <ConfigUI>
        </Field>
        </Field>
    </ConfigUI>
</DeviceFactory>
    <ConfigUI>
        </Field>
        </Field>
            <Label>Setting:</Label>
        </Field>
    </ConfigUI>
        <State id="state">
            <ValueType>String</ValueType>
</Device>
        <State id="state">
</Device>
        <State id="state">
</Device>
    new_dev.subModel = "Dimmer"
    new_dev.replaceOnServer()
    new_props['name'] = my_name
    new_dev.subModel = "Lock"
Important
You are responsible for catching all the mandatory methods for the devices you create. The Device Factory method does not create them for you.
