Dynamic Lists and Filters
    <Label>Insteon Dimmers:</Label>
</Field>
would request a list of all Insteon dimmer devices. The list would be constructed with the device name as the menu or list item viewable by the user, and the value would be the device ID.
Attributes
Attributes
Attribute Required Notes
filter No A filter attribute is not required, but if one is included, it must be set to a valid filter (see below) or empty filter="".
method No A reference to a plugin.py method that returns the list elements as described below. If not included, class must refer to one of the built-in methods (class="self" by itself will not work).
Device Filters
Class: indigo.devices
Optional Filters Description
indigo.insteon include Insteon devices - this is an interface filter that can be used with other filters
indigo.relay relay devices
indigo.dimmer dimmer devices
indigo.sprinkler sprinklers
indigo.thermostat thermostats
Trigger Filters
Class: indigo.triggers
indigo.insteonCmdRcvd Insteon command received triggers
</Field>
    return myArray
Note
Both return tuple values should be strings. Specifically, items with None as the value (first item) will be skipped. Additionally, the first tuple value (option1 and option2 in the above example) must be a string that does not contain comma or semicolon characters.
</Field>
</Field>
Note
This will cause an extra round-trip (client->Indigo server->plugin->Indigo server->client) so you should only use this when the list can change while the dialog is actually running.
Back to Configuration Dialogs
