SQL Logger Plugin¶
Configuring SQL Logger with SQLite¶
Choose the Plugins->SQL Logger->Configure... menu item, then select SQLite as the database type.
/Library/Application Support/Perceptive Automation/Indigo 2026.1/Logs/indigo_history.sqlite
Configuring SQL Logger with PostgreSQL¶
- Download a PostgreSQL installer. Note there are other installers available elsewhere as well.
Add the path to the PostgreSQL binary to your bash profile file. From the Terminal copy/paste:
echo 'export PATH=$PATH:/Library/PostgreSQL/bin' >> ~/.bash_profile -
Next, open the System Preferences and choose the PostgreSQL Server icon that was added. You should now be able to start the server. Note that some installers seem to include a Server Manage.app application, but they may not work correctly. However, the panel in the System Preferences does appear to work.
From the command line you can now try to connect to the server via:
psql -U postgres -
Next, select the
Plugins->SQL Logger->Configure...menu item, then selectPostgreSQLas the database type.
Logging Options¶
From the SQL Logging configuration dialog (Plugins->SQL Logger->Configure... menu item), you can choose which information the plugin should store in the database and specify if older data should automatically be pruned:
Database Table Format¶
and
Using SQL you can query the table for all the defined columns.
Variable tables are similarly created -- one table per variable. However, they always have the same columns: ts and value. Here is an example table tracking a variable for alarmMode:
| ts | value |
Example Queries¶
PostgreSQL Queries¶
SQLite Queries¶
Note that when selecting the timestamp from a SQLite table you must use the notation datetime(ts,'localtime') so that the internally stored GMT time is translated to your local time.
Events¶
Indigo Internal Errors are errors generated by the IndigoServer directly - so errors from Insteon and X10 devices, errors with the built-in actions/events (sending emails), etc. These do not include errors that plugins generate or errors that are inserted from scripts.
To use the Specific Type event type, you'll need to use the error type that's shown in the event log window. The error type is the beginning part of an event log line. Each event log entry has a beginning part, then a series of spaces, then the message. The beginning part is the event type. Error event types will always end in the word "Error". Here are some examples:
Aug 9, 2012 3:38:10 AM
My Type Error this is an error from a script
NOAA Weather Plus Error Error parsing XML from NOAA for device Weather Forecast: not well-formed (invalid token): line 1, column 111
In the configuration dialog for Error in Event Log, when you select Specific Type from the Errors to monitor for: popup, a text field with the label Event Type will show. You'll enter the text shown above - so for instance if you want to monitor for the first error, you'd enter "My Type Error" in the text field (notice no spaces/tabs before or after). Then, every time an error of that type is detected by the SQL Logger plugin, it will fire that trigger.
This is primarily useful for plugin errors although if you have scripts that generate errors it could be used for those as well. For plugins (unless the developer decides otherwise), errors will be generated using the plugin's name with " Error" appended.
You can enter text in the String to Match field and the action will attempt to match it against the text in the log message. For instance, entering Office Lamp in the field will cause the event to fire only if "Office Lamp" is in the log message (case-sensitive). You can also specify a regular expression for more advanced text matching.
Scripting Support¶
Support and Troubleshooting¶
