Airfoil Pro
Airfoil is a great application from Rogue Amoeba that allows you to stream sound from your Mac or Windows computer to any combination of AirPlay Devices, Bluetooth speakers, and Airfoil satellite clients (iOS, Android, Mac, Windows, Linux) - and it keeps it all in sync. Many Indigo users use it in conjunction with Apple TVs, AirPort Expresses, and other computers and iOS devices to create whole-home audio systems, all streaming from your Mac/Windows computer running iTunes or other music applications.
Note
This plugin requires v1.5 or later of the Airfoil API. This was delivered in Airfoil 5 for Mac and Windows. If you need support for earlier versions of Airfoil for Mac, please see the legacy Airfoil plugin that we open-sourced. Note, however, that it may not work with newer versions of Indigo.
Airfoil Device Types
Airfoil Instance
Adding an Instance
Add Airfoil Instance Image
  • machineIconAndScreenshot.png - a screenshot from the host computer with the machine icon overlaid (though this functionality seems to be missing in Airfoil versions through v5.1.0 - you just get the same image as the machine icon)
One oversight that there is in the Airfoil API lacks the ability to know the play state of the source. So the plugin can't know whether iTunes is playing or paused. If you are using the iTunes Indigo plugin, you have this information, but it's in a different device which could make control page design a little tricky. To work around this missing functionality, we allow you to select an iTunes server Indigo device (that you've previously created) that represents the same iTunes server as the one your Airfoil instance is using as its source. The plugin will monitor that iTunes device and update the sourcePlayStatus state so that it mirrors the iTunes device.
When you click the "Save" button, the plugin will create your Airfoil Instance device, and it will query Airfoil and get all its known speakers. It will then create devices for each of those speakers (see the next section for details on those devices).
Airfoil Edit Group Image
Airfoil Triggers Image
Warning
Due to changes that Apple has made to their API, the Source Status Is Playing trigger will no longer fire. This trigger option will be adjusted in a future release.
States available to Scripts
Notes
Speaker
Each Airfoil Instance device has a collection of "Speaker" devices in its group. These are all the various outputs to which Airfoil can direct its source audio. These devices are created automatically when you create your Airfoil Instance and any time a new speaker gets added to the instance. For instance, if you create an Airfoil Instance and it finds 3 speakers, then at a later time you add a Bluetooth speaker to the Mac that Airfoil is running on, the plugin will automatically create a new speaker device for that Bluetooth speaker.
We never automatically delete speakers: if you have a Bluetooth speaker that fails, and you won't ever use it again, you'll need to remove it manually.
Warning
You can't use the Delete... button above the device list without deleting ALL the devices in that Airfoil Instance Group. If you need to delete just a single speaker, select the Plugins->Airfoil Pro->Permanently Delete Speaker menu item. This will allow you to just delete a single speaker.
An unfortunate side effect of how Airfoil handles AirPlay devices, like Apple TVs, is that if you change the name of them it will create a new speaker instance (rather than just replacing it). From the API perspective, it's just another new speaker that was added. What you'll need to do in that case is switch over any triggers, actions, and control pages that use the old speaker to use the newly created speaker, then delete the speaker manually.
If you want to use an Airfoil Speaker device in a script, here are the state details:
name string The name of the speaker in Airfoil (which is different than its name in Indigo)
type string (local, airplay, Bluetooth, group) The type of speaker
Airfoil Actions
Action Menu Image
You may also note that the action calls are inside a try block. If you specify waitUntilDone=True in your action call, you may catch an exception if something happened during the action execution. The exception message will explain in a human-readable string what occurred.
Speaker Actions
Connect Speaker
Scripting details
Action id: connect
        result = airfoil_plugin.executeAction(
            "connect",
            waitUntilDone=True
    except Exception as e:
Disconnect Speaker
Scripting details
Action id: disconnect
            "disconnect",
            waitUntilDone=True
Toggle Speaker
Scripting details
Action id: toggle
            "toggle",
            waitUntilDone=True
Save Current Speaker States
This action will save the connection state for each speaker on the selected Airfoil device. This is useful if you need to temporarily change the state of some speakers, but you want to be able to easily set them back to how they were before the change. You can optionally specify that Airfoil Group states also be saved though this option is usually not very useful since storing the current state of all speakers will usually accomplish the same as restoring a group.
Scripting details
Example 1 (no groups):
            "saveCurrentSpeakerStates",
            waitUntilDone=True
Example 2 (include groups):
            waitUntilDone=True
Restore Saved Speaker States
Scripting details
Action id: restoreSavedSpeakerStates
            "restoreSavedSpeakerStates",
            waitUntilDone=True
Set Volume
This action will cause Airfoil to set the volume of the specified speaker.
Scripting details
Action id: setVolume
            'setVolume',
            props={'volume': 50},
            waitUntilDone=True
Increase Volume
This action will cause Airfoil to increase the volume of the specified speaker by the specified amount (defaults to 5).
Scripting details
Action id: increaseVolume
volume The delta (0-100) increases the speaker's volume by - default is 5
            'increaseVolume',
            waitUntilDone=True
Example 2 (specifying delta):
            'increaseVolume',
            props={'volume': 15},
            waitUntilDone=True
Note
Because the Airfoil API doesn't directly support increase/decrease, the plugin gets the current volume from the speaker device and calculates the new volume. An unfortunate side effect is that if you send multiple increase/decrease actions in a brief amount of time, the plugin won't yet know that the speaker's volume has changed from the previous command and may not work. So space your increase/decrease commands out a bit to avoid this problem.
Decrease Volume
This action will cause Airfoil to decrease the volume of the specified speaker by the specified amount (defaults to 5).
Scripting details
Action id: decreaseVolume
            'decreaseVolume',
            waitUntilDone=True
            'decreaseVolume',
            waitUntilDone=True
Note
Airfoil Instance Actions
Disconnect All Speakers
Scripting details
            'disconnectAllSpeakers',
            waitUntilDone=True
Change Source
Scripting details
Action id: changeSource
sourceGroup One of the following: 'audioDevices', 'recentApplications', 'systemAudio'. You can see what sources are known by selecting the Plugins->Airfoil Pro->Show Sources menu item and all source groups and sources will be shown in the event log. You can also call it programmatically (as shown below with the getSources / Show Sources menu item) and it will return a dictionary of valid sources.
            "changeSource",
            props=props,
            waitUntilDone=True
Save Current Source
Scripting details
Action id: saveCurrentSource
            "saveCurrentSource",
            waitUntilDone=True
Restore Saved Source
Scripting details
Action id: restoreSavedSource
            "restoreSavedSource",
            waitUntilDone=True
Toggle Play/Pause
Scripting details
Action id: playPause
            'playPause',
            waitUntilDone=True
Next Track
Scripting details
Action id: nextTrack
            'nextTrack',
            waitUntilDone=True
Previous Track
Tell Airfoil to tell the source to go to the previous track. This only works with some sources.
Scripting details
Action id: prevTrack
            'prevTrack',
            waitUntilDone=True
Airfoil Scripting Actions
getSources
This script action will return an indigo.Dict object. The keys are the source groups, the values are lists of dicts with the following keys: friendlyName (the user-friendly name), icon (a binhex'd string that is the source's icon), identifier (the ID used in the source property above). You can unbinhex the icon and save it to a PNG file and store it somewhere for use if you like.
Action id: getSources
            'getSources',
     audioDevices : (list)
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
     recentApplications : (list)
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
    systemAudio : (list)
          Item : (dict)
               icon : [SNIP]
That's an indigo.Dict() object. Each group is the key, and the value for each group is a list of "source" indigo.Dict()'s. Each source dict has the following keys: friendlyName (the user-friendly name), icon (a binhex'd string that is the source's icon - snipped from the above example to save space), identifier (the ID used in the source property above). You can unbinhex the icon and save it to a PNG file and store it somewhere for use if you like. You can use the group name and identifier combination in the changeSource action described above.
