Dynamic Lists and Filters
    <Label>Insteon Dimmers:</Label>
</Field>
would request a list of all Insteon dimmer devices. The list would be constructed with the device name as the menu or list item viewable by the user, and the value would be the device ID.
Attributes
Attributes
Attribute Required Notes
filter No A filter attribute is not required, but if one is included, it must be set to a valid filter (see below) or empty filter="".
method No A reference to a plugin.py method that returns the list elements as described below. If not included, class must refer to one of the built-in methods (class="self" by itself will not work).
Built-in Classes
Class What the list contains
indigo.devices devices. Accepts a filter.
indigo.triggers triggers. Accepts a filter.
indigo.variables variables. Accepts indigo.readWrite to get only the ones you can change.
indigo.schedules schedules. The filter is ignored.
indigo.actionGroups action groups. The filter is ignored.
indigo.controlPages control pages. The filter is ignored.
indigo.serialPorts available serial ports. Accepts indigo.ignoreBluetooth.
Device and Trigger Filters
The filter attribute takes exactly the same strings as the IOM's iter(), keys() and len(), and is parsed by the same code on the server. Rather than repeat the tables, the complete reference lives with the IOM:
  • Device filters — the protocol, class, props.<key>, responder, controller and plugin groups, and how they combine. Tokens within a group are ORed and the groups are ANDed, so filter="indigo.relay,indigo.dimmer" widens to relays or dimmers, while filter="indigo.zwave,indigo.relay" narrows to Z-Wave relays.
  • Trigger filters — every recognized token is ANDed, so only one class token will produce a useful list.
  • Filter rules — separators, case sensitivity, and the warning that an unrecognized token is silently ignored rather than rejected, which makes a misspelled filter return more than you asked for.
Filters supplied to indigo.schedules, indigo.actionGroups and indigo.controlPages are parsed by a list that recognizes no tokens. Supplying one is not an error; it simply has no effect.
Only variables have a read-only case worth mentioning: currently only isDaylight is defined as read-only by the system, though it may become possible to create others in future versions of the API.
Another special built-in list is serial ports — use indigo.serialPorts to get a list of available serial ports, and what's returned to your plugin is the full path to the port (e.g. /dev/tty*). This is suitable for using with PySerial, which we include with Indigo. Add filter="indigo.ignoreBluetooth" to leave Bluetooth serial ports out of the list. See the "serialport" field type below for an even better way of collecting serial communication information.
</Field>
    return myArray
Note
Both return tuple values should be strings. Specifically, items with None as the value (first item) will be skipped. Additionally, the first tuple value (option1 and option2 in the above example) must be a string that does not contain comma or semicolon characters.
</Field>
One further option to dynamic lists is the ability to have them reload whenever the config dialog returns from a button or menu callback. So, for instance, if you have a button that somehow changes the contents of the dynamic list, you can specify the list as dynamically reloaded:
</Field>
Note
This will cause an extra round-trip (client->Indigo server->plugin->Indigo server->client) so you should only use this when the list can change while the dialog is actually running.
Back to Configuration Dialogs
