Events Data Passing
In this guide
How Indigo passes structured data from the event that fired — trigger details, device state changes, plugin metadata — to Python scripts and action groups. Covers the default event_data dictionary keys, plugin-specific additions, accessing data in embedded scripts, and chaining data through action group calls.
Many users ask, "How do I know what caused an action to fire?" Our server architecture never passed through any source data before. But, now we do! All built-in triggers and schedules now pass through data that's specific to the event. Here are the basics.
Events now pass an indigo.Dict that contains data about the firing event, be it a trigger, schedule, or an event that your plugin may provide. By default, every event dictionary will contain the following:
    "event-indigo-id": 1214985350,  # the ID of the trigger, schedule, action group, etc.
  1. server - this is what will show if the server performed the event on its own during the normal course of operations. A device state change trigger, a schedule fires, etc.
  2. python - this is what the source would be if the operation was started via an IOM command. So if you did a indigo.actionGroup.execute(12345) this is what the source would be.
  3. api-http - similar to python above, but if the command came in through the HTTP API.
  4. api-websocket - similar to api-http, but the command would have come through a websocket.
    "event-plugin-event-id": "zwaveCommand",  # ID of the plugin supplied event
    "event-plugin-id": "com.perceptiveautomation.indigoplugin.zwave",  # plugin id
    "event-plugin-name": "Z-Wave",  # plugin name
How do you pass data through?
message = {"somekey": "some value"}
message can be either an indigo.Dict or a normal Python dict instance, the server will convert it to an indigo.Dict before passing it along. It's just that simple.
  • You won't want to duplicate any of the above built-in names as it would get overwritten.
  • You probably want to name your keys with something that's easily identified with your plugin. For instance, the Z-Wave plugin uses the prefix zwavecmd- for its keys that describe the event data that it passes through.
  • We tried to use dashes - as separators rather than underscores - we think that's a better option for string keys.
  • Keys should follow the restrictions on indigo.Dict keys (alphanumeric, dash, underscore, starting with a letter).
FYI, you can pass arbitrary data around using the IOM and the various .execute() actions on Triggers, Schedules, and Action Groups. Just pass through trigger_data, schedule_data, event_data respectively to those function calls when performing them through the IOM.
How will users use the data?
    # here.
    pass
Regardless of where the data came from (trigger, schedule, etc.) the variable name will be event_data.
Then, once the conditions have been evaluated, the event_data will become available to actions. We've updated the built-in actions where appropriate to use the data.
There is also a new substitution, %%e:"path"%% that can be used anywhere a substitution is valid. If the user wants the whole thing, they would just use the empty string %%e:""%% and the entire string will be inserted. Again, simple types will be inserted directly, complex types will be inserted as JSON.
                 action: Any,
                 dev: Any,
This is a complete action handler with type hints. While we don't envision a scenario where event_data is passed None, it's possible that it may happen or could be optional at some point in the future. Your code should make sure that the data is present before assuming anything.
Examples of How Events Data Can Be Used
There are likely a lot of different scenarios where event_data is useful, but it may be helpful to see a complete working example all in one place. Here is a simple example just to show how straightforward the mechanism can be.
Create an Action:
  • Create an Action Group called "Log Event Data"
  • Select Server Actions > Script and File Actions > Execute Script
  • Select Embedded Python and enter the following short script into the code block. Notice that we didn't do anything special to access the event_data payload. It's automatically supplied by the host process when the script is called due to an event.
indigo.server.log(f"{event_data}")
  • Select OK
Create a Trigger to fire the action:
  • Create a Trigger called "Log Event Data"
  • You can link it to an event, but for this example the event type doesn't matter
  • You can also set a Condition, but for this example the condition doesn't matter either
  • On the Actions tab, select Server Actions > Execute Action Group
  • Select the "Log Event Data" Action you created above
  • Select OK
Now, from the Actions list in Indigo, highlight the "Log Event Data" Trigger and select Execute Actions Only. When your Trigger fires the script, something similar to the following should appear in the Events log:
Trigger                         Event Data Trigger
   Action Group                    Event Data Example
   Script                          EventDataDict : (dict)
     event-indigo-id : 553162605 (integer)
     event-type : DeviceStateChangeTrigger (string)
     source : server (string)
     timestamp : 2025-10-31T10:18:37 (string)
It's that simple.
Get Creative
The new event_data mechanism opens up a lot of possibilities for plugin developers. One thing that comes to mind almost immediately would be for plugins that provide virtual devices/wrappers/shims to allow the user to specify a path in the data then map that into either a custom state or a property (onState, etc.) Combine this functionality with Webhook functionality and it would be possible to have a webhook directly update a virtual device. This would reduce a lot of glue code necessary now in handling those types of things.
