Accessing Indigo Remotely¶
Remote Indigo Access¶
Modifying Firewall Settings¶
Discovering the Indigo Server IP Address (LAN only)¶
and a wired Ethernet connection might look something like this:
Remote Access Using the Indigo Client¶
- Double click the
Indigo 2025.2application (inside/Applications/Indigo 2025.2.app) on the remote Mac. - If this is the first time to run Indigo on this remote Mac, then press the
Connect to Remote Server...button in the connection status window. - If you are wanting to connect to a different Indigo Server, then select the
Indigo 2025.2->Connect to Remote Server...menu item. - Enter the
Connectbutton.
Indigo Mac Client and the Indigo Reflector
The Indigo Mac Client doesn't use the Indigo Reflector service. Connecting an Indigo Mac Client to a server over the internet is a complex topic that is well beyond this document – we suggest you search our online forums for others that have configured this type of access.
Remote Access Using Indigo Touch¶
Remote Access Using a Web Browser¶
http://192.168.1.23:8176/
Indigo Touch and Your Reflector¶
Reset Your Reflector's Activation¶
Indigo 2025.2->Stop Server) but don't quit the Indigo Client - Switch to your browser and log out of your Indigo Account
Start Local Serverbutton
Manual Reset¶
Go->Go to Folder… - In the resulting dialog, copy and paste the following:
/Library/Application Support/Perceptive Automation/Indigo 2025.2/Preferences/ - In the resulting Finder window, delete the folder named
