Installation & Server Setup¶
Installing Indigo¶
Location of Indigo Files after Installation¶
The Indigo 2025.2 application can be found here:
/Applications/Indigo 2025.2.app
/Library/Application Support/Perceptive Automation/Indigo 2025.2/
Note
This is the Library folder at the top level of your hard drive, not the one in your User folder. Lion and greater hide these folders by default, but if you select the Go->Go to Folder… menu item in the Finder and paste in the path above it will open that folder in a Finder window.
Installing Indigo Client on another Mac (optional)¶
Repairing an Installation¶
If you experience issues with your Indigo installation, such as file permissions or missing or corrupt python modules, you can attempt to repair those by rerunning the Indigo installer. This will reinstall the Indigo application and all of its dependencies but it will not touch your Indigo database, plugin preferences, or scripts you've added to the shared directories. This is the standard way to get Indigo back to it's installed state.
Starting Indigo Server¶
- Double click the
Indigo 2025.2application (/Applications/Indigo 2025.2.app). - If this is the first time to run
Indigo 2025.2on this Mac, then press theStart Local Server...button in the connection status window. - If you want to reconfigure the Indigo Server on a Mac already running Indigo, then select the
Indigo 2025.2->Start Local Server...menu item.
Password Field Behavior
The length of the entry in the password field does not reflect the length of the actual password entered. This is intentional and is meant to add a layer of security so a bad actor can't guess the true password's length.
Standard startup mode¶
Outgoing reflector port selection: Some ISPs, especially satellite providers, may block incoming and outgoing connections -- particularly if they sit idle for a time (which, in our opinion is ridiculous) -- this setting provides a few options to hopefully work around these limitations. The setting you choose does not have any impact on performance. Further, the reflector port selection (or, in fact, the reflector itself) should have no impact on local web traffic performance (since the reflector isn't involved when a local network connection is made). If you're experiencing slowness with a local connection, check your router to ensure it isn't blocking or otherwise interfering with Bonjour traffic.
Custom single app startup¶
Starting the Server¶
If this is the first time you've started the server, you'll be prompted first to click through our End User License Agreement (EULA), then you'll see the Indigo Account Log In dialog:
Backing Up Indigo¶
Time Machine will do this by default. To recover, just recover that directory and then run the Indigo 2025.2 installer again (which will repair any permission issues that Time Machine may have introduced).
General Configuration Settings¶
You can configure other Indigo settings by opening the preferences dialog (selecting the Indigo 2025.2->Preferences... menu item) and clicking on the General tab.
You can have Indigo check for updates immediately by selecting the Indigo 2025.2->Check for Updates... menu item.
Specifying your Latitude and Longitude¶
Configuring your System Location¶
- Choose
Date & Timeicon. - Select the
Closet Citylocation is not near your location, then follow the instructions on the panel to choose your location. If you would like to precisely specify your location, then you can override the system location from within Indigo.
Overriding the System Location¶
- Choose the
Indigo 2025.2->Preferences...menu item, then make sure theSunset & Sunrisetab is selected. - Select the
Modifying System Settings for Continuous Operation¶
Modify Energy Saver Settings to Prevent Computer Sleep¶
- Choose
Energy Savericon. - Move the
