SQL Logger Plugin
Choose the Plugins->SQL Logger->Configure... menu item, then select SQLite as the database type.
  • Download a PostgreSQL installer. Note there are other installers available elsewhere as well.
  • Add the path to the PostgreSQL binary to your bash profile file. From the Terminal copy/paste: echo 'export PATH=$PATH:/Library/PostgreSQL/bin' >> ~/.bash_profile
  • Next, open the System Preferences and choose the PostgreSQL Server icon that was added. You should now be able to start the server. Note that some installers seem to include a Server Manage.app application, but they may not work correctly. However, the panel in the System Preferences does appear to work.
  • From the command line you can now try to connect to the server via: psql -U postgres
  • Next, select the Plugins->SQL Logger->Configure... menu item, then select PostgreSQL as the database type.
Logging Options
From the SQL Logging configuration dialog (Plugins->SQL Logger->Configure... menu item), you can choose which information the plugin should store in the database and specify if older data should automatically be pruned:
Plugin SQL Logger Configuration Image
Database Table Format
device_history_9734822, device_history_12452348, device_history_8734522 and variable_history_9872345, variable_history_3411246
ts brightnesslevel onoffstate
2012-05-16 16:00:32 0 f
2012-05-16 16:01:44 74 t
2012-05-16 16:01:44 29 t
2012-05-16 16:44:46 0 f
2012-05-16 16:45:03 29 t
2012-05-16 16:45:35 0 f
2012-05-16 18:20:09 28 t
2012-05-16 19:01:57 29 t
2012-05-16 19:15:12 38 t
2012-05-16 19:15:13 48 t
ts temperature humidity
2012-05-16 16:00:32 73 85
2012-05-16 16:01:44 74 85
2012-05-16 16:01:44 73 85
2012-05-16 16:44:46 72 86
2012-05-16 16:45:03 71 87
2012-05-16 16:45:35 68 87
2012-05-16 18:20:09 65 88
2012-05-16 19:01:57 67 87
2012-05-16 19:15:12 68 86
2012-05-16 19:15:13 69 86
Using SQL you can query the table for all the defined columns.
Variable tables are similarly created -- one table per variable. However, they always have the same columns: ts and value. Here is an example table tracking a variable for alarmMode:
ts value
2012-05-16 16:00:32 Idle
2012-05-16 16:01:44 Arm Home
2012-05-16 16:01:44 Idle
2012-05-16 16:44:46 Arm Away
Example Queries
PostgreSQL Queries
PostgreSQL query to retrieve all event log history: psql indigo_history postgres -c "SELECT * FROM eventlog_history;" PostgreSQL query to retrieve all device history for a specific device: psql indigo_history postgres -c "SELECT * FROM device_history_692773228;" PostgreSQL query to retrieve the timestamp, rain rate and rain total from an Oregon Scientific rain sensor: psql indigo_history postgres -c "SELECT ts, rainrate, raintotal, currentdaytotal FROM device_history_849210623;"
SQLite Queries
For SQLite queries, first change to the directory in which the database file resides: cd /Library/Application\ Support/Perceptive\ Automation/Indigo\ 6/Logs/
SQLite query to retrieve all event log history: sqlite3 -header -column indigo_history.sqlite "SELECT * FROM eventlog_history;" SQLite query to retrieve all device history for a specific device: sqlite3 -header -column indigo_history.sqlite "SELECT * FROM device_history_692773228;" SQLite query to retrieve the timestamp, temperature, and humidity from an Oregon Scientific sensor: sqlite3 -header -column indigo_history.sqlite "SELECT datetime(ts,'localtime'), temperature, humidity FROM device_history_167703743;"
Note that when selecting the timestamp from a SQLite table you must use the notation datetime(ts,'localtime') so that the internally stored GMT time is translated to your local time.
Events
SQL Logger Event Image
Indigo Internal Errors are errors generated by the IndigoServer directly - so errors from Insteon and X10 devices, errors with the built-in actions/events (sending emails), etc. These do not include errors that plugins generate or errors that are inserted from scripts.
To use the Specific Type event type, you'll need to use the error type that's shown in the event log window. The error type is the beginning part of an event log line. Each event log entry has a beginning part, then a series of spaces, then the message. The beginning part is the event type. Error event types will always end in the word "Error". Here are some examples:
Aug 9, 2012 3:38:10 AM
In the configuration dialog for Error in Event Log, when you select Specific Type from the Errors to monitor for: popup, a text field with the label Event Type will show. You'll enter the text shown above - so for instance if you want to monitor for the first error, you'd enter "My Type Error" in the text field (notice no spaces/tabs before or after). Then, every time an error of that type is detected by the SQL Logger plugin, it will fire that trigger.
This is primarily useful for plugin errors although if you have scripts that generate errors it could be used for those as well. For plugins (unless the developer decides otherwise), errors will be generated using the plugin's name with " Error" appended.
You can enter text in the String to Match field and the action will attempt to match it against the text in the log message. For instance, entering Office Lamp in the field will cause the event to fire only if "Office Lamp" is in the field (case-sensitive). You can also specify a regular expression for more advanced text matching.
Scripting Support
Support and Troubleshooting
