EasyDAQ Relay Card Plugin
Cards Supported
  • USB24MxS (24 relays)
  • USBDIO24 (24 DIO channels)
Adding Cards to Indigo
Next choose the File->New Device... menu item, select Plugin from the Type popup control, and EasyDAQ Relay Card from the Plugin popup control, and choose the correct Model. Press the Edit Device Settings... button to configure the card:
Easydaq Settings Window Image
Controlling Relay and Digital Outputs
Easydaq Action Panel Window Image
Some actions have additional options available via the Edit... button. For example, the Change Multiple Outputs action allows you to control (turn on, turn off, or toggle) all the outputs with a single, and very fast, action:
Easydaq Action Change Multi Window Image
Triggering Actions on a Digital Input Change
Indigo will automatically track all input and output channel states. To trigger an action when a particular channel state changes from OFF to ON (or ON to OFF) choose the File->New Trigger menu item, and select Device State Changed from the Type popup control. Next, select the Indigo device representing the EasyDAQ card you want to monitor, and then choose which channel change will cause the trigger:
Easydaq Trigger Device State Change Window Image
Preventing Floating Input Problems
Scripting Support
Action specific properties
Turn On Output
Action id: turnOnOutput
Properties for scripting:
plugin_id = "com.perceptiveautomation.indigoplugin.easydaq-usb-relay-cards"
easyDaqPlugin = indigo.server.getPlugin(plugin_id)
if easyDaqPlugin.isEnabled():
    easyDaqPlugin.executeAction(
        "turnOnOutput",
        deviceId=131523919,
        props={'channelSel':1}
Turn Off Output
Action id: turnOffOutput
        "turnOffOutput",
        deviceId=131523919,
Toggle Output
Action id: toggleOutput
        "toggle",
        deviceId=131523919,
All Outputs On
Action id: allOutputsOn
        "allOutputsOn",
        deviceId=131523919
All Outputs Off
Action id: allOutputsOff
        "allOutputsOff",
        deviceId=131523919
Action id: changeMultiple
channelSel# this is the command for the channel and must be one of the following: "turnOn", "turnOff", "toggle" - note that you should have separate properties for each channel, see example below for details
        "changeMultiple",
        deviceId=131523919,
        props={
            'channelSel1':'turnOn',
            'channelSel8':'toggle',
            'channelSel17':'turnOff'
Pull-Up and Pull-Down Resistors
Home automation often involves interfacing with contact closure type switches. Some examples include: alarm magnetic reed door/window switches, water float level switches, push button switches, etc.
Some input hardware can be directly wired to these switches, such that the INPUT pin/terminal goes directly to one switch wire while the other switch wire is connected to +5V. This hardware, like the Insteon I/O-Linc, has an internal circuit so that it can specifically be used for contact closure type circuits.
However, some TTL based input hardware will have a "floating input" problem when the switch is open. In such an open state the INPUT pin on the hardware will be connected to nothing and the TTL circuitry will bounce between showing ON and OFF. You'll know this is a problem because there will be a continuous stream of changes logged inside Indigo when the switch is in the open state.
The solution in this case is to use a pull-up resistor (RadioShack will have the 10K resistor needed) so that the INPUT pin is never left in a floating, or unconnected, state:
Pull Up Resistor Image
When the closure switch is in the open state, the INPUT pin is pulled up to +5V through the 10K resistor. When the closure switch is in the closed state, INPUT will be forced to GND (+0V). Note the 10K resistor is needed so that there isn't an unloaded (no resistance) short between +5V and GND when the switch is closed. By using a 10K resistor, only a tiny amount of current will flow from +5V to GND when the switch is closed.
Note the above circuit will have INPUT pulled to +5V when the circuit is open, and INPUT will be GND when the circuit is closed. If this is the opposite of what you want, then you can use a pull-down resistor circuit instead:
Pull Down Resistor Image
Support and Troubleshooting
